derzuuummm
Ich erhalte unregelmäßig alle paar Wochen einen BSOD wegen der Datei Ntoskrnl.exe.Heute hab ich zum ersten mal einen wegen NETIO.sys bekommen.An was könnte das mit Ntoskrnl.exe liegen?Hier meine Infos:
System Information (local)
computer name: LEON-PC
windows version: Windows 7 Service Pack 1, 6.1, build: 7601
windows dir: C:\Windows
CPU: AuthenticAMD AMD FX(tm)-8350 Eight-Core Processor AMD586, level: 21
8 logical processors, active mask: 255
RAM: 17176948736 total
VM: 2147352576, free: 1922215936
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash Dump Analysis
Crash dumps are enabled on your computer.
On Sun 15.06.2014 19:38:55 GMT your computer crashed
crash dump file: C:\Windows\Minidump\061514-11996-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x75B90)
Bugcheck code: 0x1E (0x0, 0x0, 0x0, 0x0)
Error: KMODE_EXCEPTION_NOT_HANDLED
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Wed 04.06.2014 16:06:41 GMT your computer crashed
crash dump file: C:\Windows\Minidump\060414-11091-01.dmp
